查看: 3898|回复: 0
[塑料] K 2013 Preview: Materials & Additives K展瞭望:材料与助剂
发表于 2013-10-18 09:02:45 | 显示全部楼层 |阅读模式
本帖最后由 846082533 于 2015-12-31 15:00 编辑 <br /><br />
K展瞭望:材料与助剂
Performance, Economy & Sustainability Drive Materials & Additives Developments
By Lilli Manolis Sherman, Senior Editor rom: Plastics Technology Issue: September 2013
Originally titled 'Performance, Economy & Sustainability Drive Materials & Additives Developments'
The K 2013 show will present a broad range of engineered plastics materials, including thermoplastic composites, as well as additives. Automotive and electronic applications will be the main targets, as well as medical, packaging, lighting, and construction.
K2013塑料展览将推出宽范围的工程塑料材料,包括热塑性复合材料、助剂。汽车和电子电器是主要目标,还有医疗、包装、照明个建筑。
[tr][td]  The K 2013 show will present a broad range of engineered plastics materials, including thermoplastic composites, as well as additives. Automotive and electronic applications will be the main targets, as well as medical, packaging, lighting, and construction.
TOUGHER, LIGHTER ENGINEERED PLASTICS更韧更轻的工程塑料
Several specialty nylon compounds, along with two unique engineered PET materials, an ultra-low-friction acetal, and reinforced PC are among the crop of new materials. 几个专用尼龙共混物以及两个独特的PEY工程材料,一个超低摩擦系数POM和一个增强PC,是其中的几个新材料。
[/td][/tr]
[/table]
此外,BASF的吹塑牌号Ultramid Endure是专门稳定的PA66,用于汽车发动机罩下部件。该牌号连续使用温度为220℃,最高温度可耐240℃,该牌号D5G3 BM grade (15% glass)可用于涡轮增压器与中冷器之间的连接管道。
BASF also has a new portfolio of special Ultramid nylons for furniture. Ultramid SI (surface-improved) grades reportedly provide a high-quality surface appearance. One of the first items made with Ultramid SI is the MOVYis3 office swivel chair, which BASF developed in  collaboration with furniture maker Interstuhl.
